Deleted member 89023
What's the best way to remove GT85 from a brake disc? Thanks.
Isopropyl alcohol should do the trick.
You can get disc brake cleaner which is basically that. Make sure you clean the rotor and pads and then bed everything back in properly.
Would something like 2000-3000 grade wet and dry take it off? Asking not recommending btw.
https://www.toolstation.com/holts-brake-cleaner/p43710?searchstr=holts If you have a Toolstation near you, this stuff is very good value.What's the best way to remove GT85 from a brake disc? Thanks.
Go for a ride on a cinder/gravel track and use the brake as few times.
Scuffing from grit on the path will soon fettle it.
