Justinslow
Lovely jubbly
- Suffolk
So I'm seeing my osteopath and NHS physio (GP was useless) for lower back and groin/leg problems.
I struggle with my back through my job which is physically demanding but for a few months now I've had another problem. My left leg is persistently stiff from the groin downwards through the hamstring, no amount of stretching is able to shake it off. I've had another osteopath session tonight and she really worked the groin area pretty hard, it's eased the dull ache and stiffness for now but I'm sure I'm going to smart a bit tomorrow!
Looking back over the last couple of years I think I've always had a groin issue, I tend to ride with my saddle a bit lower than it probably should be, resulting in my knees sticking out a bit. When I ride I generally get a dull ache deep within my left groin never my right groin, raising my saddle makes this worse. It's not horrific and I have been able to complete rides over 120 miles, however, lately the groin is tender and the leg very stiff (my right leg is fine) and getting worse not better which leads me back to my first paragraph.
I initially went to the osteopath as I thought it may be my back causing the issue but now I believe the groin is the cause.
I haven't ridden my bike in over a month and the symptoms haven't subsided.
The osteopath said if I continue with physio and the groin problem doesn't get better I should eventually get referred for a scan on the NHS, I can't go direct to a scan I have to go "round the houses" first.
Has anybody any experience of the symptoms I describe or what might be going on, the osteopath reckons it is in the area of the upper hamstring and lower abductor muscles around the pelvic area (or something like that)??
Cheers.
Cheers.
