Handlebar bag
Simon_m
Afternoon guys. Can any of you recommend a good handlebar bag with a clear map pouch on top? I don't need anything large, its just for camera, extra water bottle and a few nibbles to eat along the way. Also to put a lightweight coat or something similar in when the day warms up or drys out, and of course, for the opposite to happen.
There seem to be so many on the market and I'm not sure which one/brand to go for. Any ideas? Thanks
stumpy66
Lanarkshire
I bought the ortilieb ultimate, great quality, easy to remove, has a shoulder strap. You can buy a the map case as an extra
Scilly Suffolk
I've got one of these, I can't recommend it over anything else as I've not tried any others but it worked for me.
I bought it last year and only used it for the Summer; I now use a saddle bag, so if you want it, you can have it for a tenner plus postage.
Simon_m
Simon_m
Hi Andy, I was not too sure which one yours was, is it the classic?
Thanks Jimmy, thats very generous of you. The link went just to their website, not to the product though. Could you send again or something? Thanks
Simon_m
Simon_m
ok thanks. I need something a bit harder wearing, good luck with the Aldi one and the ride itself
Scilly Suffolk
Strange, it worked earlier. Try this or this.
Mine is, presumably, a later model as the logo on the front is slightly different and the backplate is noticeably stiffer than the rest of the body (see the Bike Radar review).
To give you an idea of capacity, it comfortably holds six large tins of beer upright, so it would be ample for your stated needs.
Simon_m
Simon_m
ah those links work, thanks. Do you have a model number or something? Their review says the back is a bit flimsy, has the update on yours helped?? Sounds ample yes, I will do a bit more research on it as at work at the moment and boss is lurking around somewhere lol, and I will let you know. Thanks Jim
Falwheeler
Scilly Suffolk
ah those links work, thanks. Do you have a model number or something? Agu Ventura 120 CG Their review says the back is a bit flimsy, has the update on yours helped?? "Mine is, presumably, a later model as the logo on the front is slightly different and the backplate is noticeably stiffer than the rest of the body (see the Bike Radar review)." Sounds ample yes, I will do a bit more research on it as at work at the moment and boss is lurking around somewhere lol, and I will let you know. Thanks Jim
P.H
I have one of those, well the identical Vaude version, it's the perfect size but not waterproof. It has a waterproof cover, which also covers the map... It's a pity no one makes a really waterproof bag in that size.
I also have a Vaude Aqua bag, with I preferred to the current Ortlieb when I compared them side by side. I also like the Klick-Fix fitting used by a few bag manufacturers, there's a range of accessories and spares are available, it also means you can swap bags.
http://www.actionoutdoors.co.uk/outdoor_gear/info_10915_vaude_aqua_box_bar_bag.html
al-fresco
Growing older but not up...
Shropshire
My wife got me an Ortlieb Ultimate for carrying my camera. (Nice of her because it was bloody expensive!) The map pocket is an optional extra. Like all Orlieb stuff the quality is great and I have no qualms about carrying an SLR and lenses in it. One snag is that you can't use a normal handlebar mounted light with the bag - the top of the bag would be in the way of the beam.
stumpy66
Lanarkshire
Yeah the classic one, quality bit of kit, shop around for deals, I think I bought mine at spa cycles, was the cheapest at the time
I got a cheap o from Halfords and it worked well, then I bought a bigger Altura via E Bay for touring with but it had Klickfix fittings. So I had to take the Halfords off. When I finished my trip I found I could get a Klickfix back plate. So I took the Halfords backplate off and replaced it with a Klickfix. Now I use both bags but acctually preffer the Halfords.
Simon_m
Simon_m
Morning, wow lots of input. Oooo that looks good Falwheeler, "Revolution Adventure Bar Bag 3L " cheap too.
Thanks again Jim. "Vaude Aqua bag" is pretty pricey, thanks to Andy and the others too.
Hmmm kinda torn now lol. The Revolution Adventure Bar Bag looks good as is Jims. Not thought about the lights, what do you do with them?!! Also have to work out if the bag will fit the front of the bike with all the wires as it's going onto my road bike - pictured in profile
