thank you anyway.no idea, no & no.
sorry.
That was a blooming good idea vickster, they are the stock bars and it would appear that it's an internal measurement!Presuming you have Giant bars at the moment, why not measure them and then compare against the spec?
I don't think cheap carbon bars are much cop from what I've read
I want to go a bit wider, so I'm just having a mooch about and thought the Chinese carbon were a good price, though in all honesty I did suspect that they may be a little too good to be true, but it's always worth asking.Just feedback on here
What are you trying to achieve with the bars?
I've always felt a little squeezed by it and as the tape need replacing I thought I may as well do the bars and the stem at the same timeAbout the only thing I actively dislike about my lovely Giant, is the esoteric handlebar width. I measured mine (outer diameter) at 26.0mm which isn't even one of the two more common standards!
If I were you and getting a new handlebar, I would get 31.8mm ("oversize") as 90% of bikes run this size now, and then invest in an appropriately sized stem, and chuck the Giant's own set into a bin of crap at the back of the shed.
Am I being daft here Cyclist, if I want to go wider I need to know the width of the bars I currently have first don't I?In that case, does it matter what the diameter of the Giant handlebar is? If you're doing both bars and stem...
They look spanking fossyant, thank you very muchYou'd be better off with Ritchey WCS alloy bars. Almost as light as their carbon version, stiffer than the carbon, and at least half the price. I wouldn't be touching cheap Chinese carbon bars. Any voids in the resin could be dangerous.
