Hard-to-reach radiator valve?
DaveReading
Don't suffer fools gladly (must try harder!)
Reading, obvs
Having squeezed an Ikea wardrobe into the corner of the room we use for the grandkids, overlapping the radiator by about 6 inches, I find that I can't reach past it to turn the valve on or off.
I had naively assumed that this would be a common problem (!) and that it would be possible to buy off-the-shelf some kind of extension handle that I could engage with the valve from above the top of the radiator. A bit like this:
although that's designed to fit a stopcock rather than a radiator valve.
I can't find one anywhere - can anyone suggest a source, or am I looking at a DIY effort?
Deleted member 26715
Why do you need to get to it, can you not get to the one at the other end & leave that one open?
U
User6179
If you can reach the other valve on the other side just turn it off there .
Buy a plastic filler with a top diameter big enough to fit over the valve handle. Attach the small end of the filler to a wooden rod long enough to get down to reach the valve.
There's no valve at the other end - it's an elderly dual-entry radiator (both entry and exit pipes at the same end).
Can you get to the pipe work anywhere else & put another valve inline
sight-pin
I take it it's a TRV type valve your wanting to adjust, as the other end should be a lockshield valve, if you adjust that you could alter your system balance.
DaveReading
Reading, obvs
Yes, I was thinking along those lines.
But I've just had another look at the existing knob - I thought it was hexagonal but it's actually 5-sided so I'm not sure whether I can find anything the right shape to grip it.
Is it a thermostatic type or just the old style off/on
