astrocan
- Abingdon, Oxon
I have replaced the headset bearings on an 11year Trek 2000.
I cannot find the balance between a slack stem and stiff steering.
The bottom set came out really easily and, after cleaning up the seat in the bottom of the head tube the new set have pushed in really easily too. No need for a press to install or a rocket to remove.
I suspect that the seat has become enlarged, possibly through corrosion, possibly through inexpert previous installation.
I can resolve this by applying sufficient pressure through the cap nut to pull the bearing into the seat, but that is great enough to make the steering unacceptably stiff and will cause premature bearing wear. Ease the pressure and immediately the steering is lighter but the slack returns and I cannot find an ideal adjustment.
Has anyone tried using a bearing lock compound in this situation or experience of similar situations.
Alternatively is an oversize bearing an option? If so where from?
Thanks for your time
