sh - you've reminded andy of the malignant British bird hazard.Aren't hedges normally cut at this time of the year as it's before birds start building nests, in the Spring..
Still darned annoying when the thorns are scattered across the road, though!
your location says Lincs - where do you manage to ride then?
I get very few punctures, weather I can cope with, yes some bad potholes but not specifically a Brit thing. Bad driving ditto.
Yep, I've done a bit of 'Hedge Laying' when I worked on Watermead Park, it gives a real sense of achievement in sorting out an unruly mess into something functional. It also allows Trees that are growing in the hedgerows a chance to develop increasing wildlife habitat plus who wouldn't want to use a tool called a Billhook.Try doing it by hand for a few miles and you would soon change your mind!!
But of course they must be the last nail in the coffin for uk roads. I personally have never had a thorn on my road bike.... perhaps they recognize me.😉
Whenever I pass one of those contraptions I wonder how often sharp bits of hedge get thrown out at speed and what would happen if they hit you.Aye that hedge cutting device on the back of a Tractor was the invention of Satan.![]()
Yep they start early here too but seem to spread it out till March. 2 got thorns on our Xmas ride so we were twice delayed as it wasn't punctures together but one straight after the other had repaired. Thought Mrs 26 and I had been lucky and in some sense we were as Mrs 26's tyre went down later after we got back. Fortunately I spotted it and fixed it in the warm and dry (that's the lucky bit I guess) before our next outing. I have been known to pick my bike up and walk it through particularly dense hedge cutting debris.The farmers do hedge cutting in August/September time around here.
The last trouble I had with brambles wasn't the bike.Uncut brambles ( I think you call them blackberries ) spreading across a path can also be a problem.
... before flicking the Vs at you vigorously as soon as your back was turned.Freely available to busybodies in any part of the world.
Strange to relate, the interfered with person in this tale didn't take against it.
Further, he said: "Good plan," when I suggested spinning the wheel.
The flails are responsible for the "cutting", more pulverising than cutting, with the skirt mounted on the "cutting head", slowing down all debris.Whenever I pass one of those contraptions I wonder how often sharp bits of hedge get thrown out at speed and what would happen if they hit you.
Could take an eye out with one of thoseThe flails are responsible for the "cutting", more pulverising than cutting, with the skirt mounted on the "cutting head", slowing down all debris.
Depending on how big a piece hits you, half inch - inch, you could have a nice bruise.
Danger of being hit higher up the higher the cutting head is, and how well it's been maintained whilst in use.Could take an eye out with one of those
I generally try to look away and raise my arm to shield my face if the operator doesn't pause (some do).Danger of being hit higher up the higher the cutting head is, and how well it's been maintained whilst in use.
Hedge cutting is generally only permitted from 1st Sept to Feb 28th/29th but there are exceptions https://www.nfuonline.com/cross-sec...e-news/hedge-cutting-know-the-rules-for-2015/Aren't hedges normally cut at this time of the year as it's before birds start building nests, in the Spring..
