help me buy a helmet
ianrauk
Tattooed Beat Messiah
Rides Ti2
£10 or £100 they all do the same job.
Everyone on here will give you a different answer.
They all fit different as we all have different shaped heads, so the best thing you can do is go to your LBS and try some on first.
Specialized meet the higher snell safety standard. Go lbs and try on
Thayne
Obviously the cheaper you go the heavier the helmet is and less vents/chance to personalize the fit etc. Best thing it to try them on but keep in mind it's a potential lifesaver... in my view shelling out a bit more with that in mind is better than saving a few quid.
Edge705
Take a look at the MET Inferno UL its one of the few helmets Ive found that has a neat cut out shape at the forehead so it doesn't look to much of a blob on your head, its extremely light and pretty robust, easy adjusting straps too.
