Help removing rear cassette (see pics)
roooseter
I need help removing this rear casette, tired seems stuck, i have cassette sprocket and chain wip
T4tomo
You have the wrong tool, you need a FR 1.3 remover as that is a freewheel not a cassette
if its really jammed on - I.e big spanner wont shift it. put the end of tool in a vice and turn the wheel in the correct direction.
Overconfidentii Vulgaris
Hi and :welcome: to the site:
I may be wrong but that looks like a screw-on freewheel to me. It takes a different tool to a cassette and the whole thing unscrews rather than just undoing a lock ring. If this is the case it will need a lot of leverage - a breaker bar if you have one or I have had success in the past with extending automotive wheel nut wrenches.
Ajax Bay
East Devon
:welcome:
As @T4tomo said, you show a cassette lockring/freehub tool and you need one for a freewheel.
These are often a b****** to shift (from the image this will be its first (and ?last) time. You need to ensure the tool doesn't slip out and will (as Phil says) very likely need a steel extension to however your applying unscrewing (normal direction) torque, or maybe @T4tomo 's vice technique (care with direction but often you can't generate enough torque).
Consider whether removal is necessary.
Cycleops
Accra, Ghana
You can remove it without the tool but you'll completely destroy the freewheel. Fine if it's completely buggered. As said if you don't have to leave it.
Big John
Special tool for that one that needs sticking in a vice and then use the full diameter of the wheel to give enough leverage. A bugger to shift but very doable with the right tool AND a vice.
