Hmmm that went well......
Panter
Just call me Chris...
First ever bike build, and today my first exciting package from CRC so that I can start assembly.
I bought a BB, a headset and a stem.
The stem's too wide and the BB is for a road bike, not a MTB.
Hopeully the headset's Ok once I've read up on how to fit it ;)
Ho hum.....
Doh........... 68mm Road, 73mm MTB
Good Luck.......
Panter
Panter
Thank you ;)
The BB is actually a 73mm but the width across my frame is 68mm. Its just that according to the enclosed instructions, that model BB is designed for road and XC whereas the bike is (or will be) an all-mountain.
GrasB
Nr Cambridge
Opps, the good thing is from here on out it's almost certainly going to get better ;). Don't get discouraged though, keep on going on & you'll get there in the end. You'll probably learn a lot as well, not to mention there's a certain sense of accomplishment in completing something like a bike build.
EDIT: maybe worth getting some Vernier Calipers & less importantly Screw Pitch Gauges.
Panter
Panter
GrasB said:
Opps, the good thing is from here on out it's almost certainly going to get better :smile:. Don't get discouraged though, keep on going on & you'll get there in the end. You'll probably learn a lot as well, not to mention there's a certain sense of accomplishment in completing something like a bike build.
That's the main point really. Even in my ZINN book, I fall into the catergory whereby I'd be better off getting the shop to do it but I want to learn how to do things myself so that when something does break on the trail, at least I'll know what I've broken if not how to fix it :biggrin:
It'll be a big improvement on taking it to the bike shop and trying to explain which clicky thing or springy thing I've snapped off this time ;)
just jim
What are you building Panter? We can compare notes about steerer cutting as the time draws nearer.
Chappy
Dorchester
Dont be discouraged by it. My first build was a disaster :rofl::biggrin: still rideable though.
