swee'pea99
I'm starting to get rather ominous clunking from the BB area, and I think it's time for a change. I'm trying to figure out what axle length I need.
The one that's in there now is 110mm, but I'm not sure it's ideal. My chainset is slightly bent, and when I first fitted the BB, the sprocket just brushed the frame at one point on its revolve. The only way to make it work was to screw it in tight on the other end, then leave the chainset end slightly proud of the frame - just a couple of mm, and that worked fine. But I'm wondering, if I go to, say, a 115mm, would that solve the problem? Is there any significant downside to having 'too long' an axle?
