How can I unjam my flan cases?
PeteXXX
PeteXXX
Photo Winner
Hamtun
Next thread: How can I unjam a quiche from a flan case? :laugh:
Only joking.. I lined the base with a grease proof disc ^_^
TheDoctor
The TerrorVortex
Tomato and mushroom in a quiche?
midlife
No bacon, then isn't it just scrambled egg....
Tim Hall
Crawley
OK, purely for my own benefit. I had to figure this out.
The coefficient of linear thermal expansion of ceramics is very low. it is about 4 thousands of a millimeter per degree centigrade.
Assuming we can heat the bigger dish to 90 degrees C and cool the smaller one to 10 degrees using hot and cold water then.
Assuming ambient temperature of 20 degrees C then the big one will increase in temperature by 70 degrees and the small one decrease in temperature by 10 degrees.
The big one (200mm diameter) will grow to 200 plus 70 x 4 x 10^-3 = 200.28mm
The small one (190mm diameter) with shrink to 0.19 minus 10 x 4 x 10^-3m. = 189.96mm
The difference due to shrinkage/expansion is .32mm.
However, if the water method is used, it will have to be done upside down since the inner case will just sink down deeper.
I'm googling "upside down filling of a flat pan with water" as we speak.
No results so far.
Surely the coefficient of linear expansion is dimensionless, other than the unit of measurement of temperature. Thus the CLE of ceramics is 4x10^-6/K (or degree C), not 4 thousandths of a millimetre per degree C. The length of a lump of ceramic will increase by 4x10^-6 of its original length for each degree rise.
Change in length = Length x coefficient x change in temp
For 200mm case with 70K increase in temperature and a coefficient of linear expansion of 4 x 10^-6 change in length =
200 x 4x10^-6x70 = 0.056mm
A bigger piece of ceramic will have a correspondingly bigger increase in length for the same temperature rise (a 400mm dish will expand by 0.112mm for a 70K rise)
PeteXXX
PeteXXX
Photo Winner
Hamtun
:rolleyes:
What he said..:tongue:
