How did I get to my mid 30s and never???
Easytigers
Just fixed a puncture for the first time... It's not that I've never had a puncture before, it's just that I have always kept a couple of tubes in my pack so have always replaced rather than repaired. Used my cycling backpack for swimming with my son yesterday so took everything out...big mistake. Sod's law...I got a puncture about 3 miles from home and had the long walk home. Thought i'd have a go at fixing this time (as I'm off work at the moment).
Only problem was that I've never done one before...took me the good 3/4 of an hour (after I realised that I stuck the patch on upside down...I know...I know).
Is it worth the hassle???
PK99
SW19
i use the Park tool patches: find, sand, peel backing, press on, pump up. = what hassle?
Sunderland
Just had to fix one on my wife's bike - first time out for three years with the wife in tow! and it is hers that does it. (took me a good hour this morning to bring her iron horse and my old hack up to a ridable condition -i.e. the chain could now bend!)
We were on part of the C2C route near Sunderland and about thirty people in various cycling groups passed us - not one asked if we needed help......pretend cyclists!!!!!:cycle:
It was lucky really that I remembered to take my saddle bag off the roadie to slot into the rear pannier of my old hack (my wife likes to take lots of extras just in case!!!!) or we would have been high and dry 10 miles from home! Could not find the thorn though - argh!!!! Probably time to buy a new set of tyres and tubes for her as the ones on it are over 12 years old!
MontyVeda
I only throw a tube out if it tears where the valve meets the tube... I'm far too tight to buy a new tube when these newfangled 'elastoplast' patches make the task as quick as changing a tube.
I get the feeling people see fixing a puncture as a task and a half. I blame Blue Peter for this, as it was they who said "This is how to fix a puncture... first of all you need a bowl full of clean water in which you immerse the semi inflated tube in order to locate the puncture... this is signified by bubbles... and so on."
what they should have said was... "try to find the cause of the puncture on the outside of the tyre... this is often a thorn or bit of glass or metal. Make a note of where it is in relation to the valve BEFORE you take the tube out as this will make locating said puncture a lot easier. Failing that, remove the tube and pump it up lots. Try to locate the puncture using your ears, it is signified by a hissing sound. Home in on the puncture using your tongue as the cold air rushing out of the hole is easy to detect once you're in the right area.. use tongue to mark the location of the puncture with a little damp patch. This will not kill you as inner tubes aren't poisonous... put patch over hole." ...not all of us carry a bowl of clean water around just in case.
cyberknight
You mean your dad never showed you how to get the tyre off with kitchen spoons ?
lejogger
Wirral
Due to lack of success with my repairs and buying tubes in bulk when the good offers are on, it's generally a lot more time effective and virtually as cost effective just to throw shove a new tube in. I've got a pile of used ones in the garage that I might get round to attempting at some point
