How to paint (white) over a mahogony cabinet?
Dave7
Cheshire
As above, I have a dark mahogany** cabinet that needs painting white (satin gloss). Its going to have item on top that will stay where ther are.
My initial plan is to sand it down beforehand.
So......do I need special undercoat ?
Do i need special top coat.
NB
I know there many various more fancy types of top coat which might be of interest.
Any ideas welcome.
Thanks
**it's not real mahogany wood, it's like an old equivalent to mdf.
Oldhippy
Cynical idealist
A good cover all undercoat done a couple of times should do it with a good quality top coat. I'd avoid the cheap store brands personally. When I did the boat I was painting over brown wood in an off white. The cheapest stuff didn't do what it said on the tin.
newts
Isca Dumnoniorum
Depending on the type of existing laquer/varnish finish. Preparation, preparation can't be emphasisedenough. Clean & light abrasive for key then a specific adhesion primer that'll stick to original finish correctly. Zinnser, Carapol & Tikkurila are good products. I painted our varnished kitchen doors during lock down with Tikkurila paints, still holding up well without any signs of peeling
Tenkaykev
Poole
Our painter and decorator has recently switched to Tikkurila paint. We're very impressed with the finish.
Jameshow
Definitely avoid cheap paint. It's like water. I had to buy branded paint to go over undercoat!
We've painted our kitchen cupboard doors - really good clean, followed by sanding, then decent furniture paint - works excellently, and even stands up to the use in a kitchen. I'll occasionally touch up and bits that have got scratched off.
My wife's also done the TV cabinet with an antique effect white. And she's also 'wrapped' her mahogany sewing cabinet in a white gloss PVC wrap - looks much better in the room.
