How to place a decal on a rim?
dudigrinfeld
I have new decals and I'm wondering if someone know a method to put them on rim's flange first time properly and right?
Yeh, just stick it on straight ! :tongue:
Check how it fits, remove backing and stick on where you thought it should be. If that doesn't work, find someone who has a steady hand and a keen eye.
sidevalve
Offer it up, draw round it in soft pecil or grease pencil, peel off backing lay on inside pencil line center outwards.
02GF74
never had to do it yet but I have wondered about it.
I would imagine placing the centre first and then workin outwards for each side - that way the miasalignment will be 1/2 that is you started at one end. You would need to make a cut down the middle of the backing without cutting through the decal in order to start peeling away from the centre.
