Meltham to Emmerdale studios Road and cycle track.Define 'best'!
Easiest, safest, quickest, most scenic, on road/off road...?
Centre to centre?
Easy and safe please.Define 'best'!
Centre to centre?
While you think about it, THIS is cycle.travel's suggestion.
ThanksThat takes you up the Spen Valley greenway (NCN66 north), linking to CS1 via the RH footbath on the Rooley Lane ring road, then Cutler Heights Lane/Dick Lane then onto the Cycle Superhighway (CS1). Safe on the greenway, then either brilliant/dangerous on the Cycle Superhighway. In Armley drop down Canal Lane onto the new cycle lane alongside Kirkstall Lane and the Emmerdale studios.
It's longer, but safer.
If you're looking for easy/safe there's a direct, but less safe, route using the A62. Quicker, but dangerous.
The safer/easier route is using the Calder Valley greenway (NCN66), then through towards Ossett (NCN69) and up to Leeds Road. From there it's a wiggly route through Middleton / Belle Isle through Middleton Park/Hunslet or down Belle Isle Road, then onto the NCN66 and CS1/Kirkstall Road for the last bit. Leeds Road is the only bit that's a bit risky, with the roadside cycle lane often having cars in it.
If you can get to Leeds urban bike park, you can ride off road to Belle Isle/Hunslet Carr past the track of Middleton railway, then ride through Hunslet towards the Suzuki car dealers, and get on to the canal into Leeds, I wouldn’t recommend Thorpe Lane at Tingley into Middleton as it’s not known as the widow maker on strava for nothingThanks
Thank you for the tip .If you can get to Leeds urban bike park, you can ride off road to Belle Isle/Hunslet Carr past the track of Middleton railway, then ride through Hunslet towards the Suzuki car dealers, and get on to the canal into Leeds, I wouldn’t recommend Thorpe Lane at Tingley into Middleton as it’s not known as the widow maker on strava for nothing
It’s the nasty bit at the bottom that narrows, and is uphill near the scrapyards that’s dodgy, the drivers fly down thereThat's my commuting route - there is a path alongside but I don't use it.
There is a cycle path that goes down Dewsbury Road /A653, as for going down the dual carriageway, you’d have to have a death wish, even worse is riding up it on the dual carriageway, if you go behind the Village Hotel, there’s a cycle path that starts between the gates of Available Car and Du Puy, go to the end turn right and follow through Capitol Park to Dewsbury Road, I’ve used it on the MTB to get down to Leeds Urban Bike Park, there’s an off road trail opposite the new MacDonalds, that gets you on to the Bodmin estate which brings you out opposite the bike park gates.@DRM - I've tended to find that if you keep it wider and go fast enough it's been OK and I've used that route for about 8 years. The alternative is using the A653 dual-carriageway between Tingley and the White Rose Centre. Now that is dicing with death.
Thanks for the tipThere is a cycle path that goes down Dewsbury Road /A653, as for going down the dual carriageway, you’d have to have a death wish, even worse is riding up it on the dual carriageway, if you go behind the Village Hotel, there’s a cycle path that starts between the gates of Available Car and Du Puy, go to the end turn right and follow through Capitol Park to Dewsbury Road, I’ve used it on the MTB to get down to Leeds Urban Bike Park, there’s an off road trail opposite the new MacDonalds, that gets you on to the Bodmin estate which brings you out opposite the bike park gates.
