threebikesmcginty
Corn Fed Hick...
 - ...on the slake
All working pretty much as it should except a couple of times I've set the box to record and it hasn't. I'm not sure it can be operator error because it's so simple (yes I know, thank you!
), select prog and 'yes' to record. But then it obviously hasn't as there's no programme listed in the media bit thingy. Anyone else found this or is it just me?
 ). Since putting both inputs in the box and setting it up again (this is important - otherwise it still thinks there's only 1 input!!) it works fine and no problems.
