1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Hydraulic brake binding
Discussion in 'Bicycle Mechanics and Repairs' started by lutonloony, 11 Jan 2017.
  1. lutonloony
    lutonloony Über Member
    torbay
    have done a quick search but can't find answer. With bike on storage hanger, I gave front wheel a spin as I walked by (as you do!), notice that it does not spin as expected. After much listening, sounds like disk pad is rubbing slightly on disc. Does this imply there is crap on the pads and they need cleaning, or are there other options?
    TIA
  2. G3CWI
    G3CWI Veteran
    Macclesfield
    Take it for a ride. It will probably sort itself out.
  3. OP
    lutonloony
    torbay
    Will investigate after tomorrow's commute
  4. fossyant
    fossyant Ride It Like You Stole It!
    Some disks can be slightly out of true. You can carefully bend them straight with an adjustable spanner if you are careful. You probably need to check that the calliper is correctly aligned and the pads aren't touching.
  5. Flyboy
    Flyboy Well-Known Member
    Tranmere
    Just release the bolts holding the calliper , pull your brake then retighten your calliper bolts you will find they don't wear even , so doing this will even them back out .
    PS tighten the bolts while you are still pulling your brake ie it locks your wheel.
  6. Jody
    Jody Über legend of a forum GOD!
    Can you see daylight down both sides of the pads? If not they need to be realigned. If yes then see Fosys reply as the disc might be slightly warped. Lift the bike, spin the wheel and see if the discs is moving side to side or if it is in constant contact with one pad.
    I prefer to align by eye as it avoids the disc flexing slightly when you torque the bolts up.
  7. OP
    lutonloony
    torbay
    Thanks for advice team, shall make it a Saturday job
  8. Tom B
    Tom B Senior Member
    Lancashire
    Swap the disk black/front see if the noise moves.
    I had this a few times, once was crap pads that were the wrong shape, once it was a seized Piston and on another occasion a loose spoke that sounded just like a binding pad every time it went around.
  9. fossyant
    Psst... many bikes don't have same size disks front and back.
    Tom B likes this.
  10. OP
    lutonloony
    torbay
    Meant to say, the old slacken bolts, hold lever, tighten bolts worked a treat. Didn't realise it was literally a 2 min job!!
    Jody likes this.
