MontyVeda
- Lancaster... the little city.
if you don't tighten the bolts sufficiently, the cranks will most definitely loosen when you ride it... don't ask me how i know thisBuy a crank removal tool - I know you are concerned that the threads in the crank was damaged but the tool is steel and the crank is Al alloy: it would have done the business. But you surely need this tool in your box. How else will you remove the crankset you currently have fitted?
