I want it all in one
Ritre
I would like to get a bike mostly for my 10 mile each way commute 2-3 days/week. Half the commute is on a gravel path and dirt road and the other half is on paved roads. I'm thinking hybrid is the way to go. I also would like to do a triathlon (about 40 mile cycling) with this same bike. Any recommendations on brands, makes, models etc? I'm pretty fit, about 5 foot 6 and weigh 140 lbs. Thanks for any input!
biggs682
Northamptonshire
try a cyclo cross bike
shouldbeinbed
Rollin' along
Manchester way
+1 A cyclocross bike will beat a hybrid all ends up for what you describe. A road bike would be fine too if its just gravel paths, and would be the better Tri option.
The differences between CX & road bike are the CX will take wider tyres (better gravel grip & comfort but less tarmac pure speed), will be a bit more rugged for off road (but remember road bikes are made of metal or carbon fibre, not tissue paper), will have greater clearance for mudguards & floor to frame etc and will give you a little more relaxed, sat up position, but overall the differences between a CX & roadie are minimal compared to the difference to a Hybrid.
The advantages of both over a hybeid are primarily in the drop bars giving a more aero position for those 10 mile commutes into a howling headwind and a significant performance advantage for your Triathloning.
Drago
The Urban Fringe
So you want a Ferrari that will so out do Land Rocer off the Tarmac?
If you have the budget to buy new I too would be going down the Cyclocross route. If cash is tight then a rigid or HT MTB on slick tyres.
Ill probably be burned at the stake for heresy, but in generally not a hybrid fan. Too much a 'master of none'. Ok, the same is true of a commuterised MTB, but the cost to convert a free/cheap old nail is minimal.
Ritre
Ritre
Thanks for all the input! As is most likely obvious I don't know a lot about cycling, I know talking about brands usually stirs a big debate because people are usually very loyal but for the Cyclocross are there any specific cycles (brands and maybe models) that I should look at? Hoping around $500-$600 but I plan on using it a lot and am willing to pay more if neccesary. The gravel path and dirt road are pretty solid with a few rough patches. I don't plan on trying to dominate to the Triathlon just trying for a semi-respectbile time. Thanks again- you folks are really helpful!
Mr Haematocrit
msg me on kik for android
Specialized Crux
