Big John
I've never thought I had the need for an impact driver. I've two cordless drills and for a lot of jobs I use one for drilling and the other as a cordless screwdriver. Drill a pilot hole in wood with one drill, for example, and drive the screw in with another drill. Ok, the plan is to put new guttering up at the front. I'm going to be working off a ladder with only one pair of hands, mores the pity. I thought an impact driver would help proceedings e.g. one hand holds the screw and the impact driver does the work of my two cordless drills i.e. drives the screw in without a pilot hole. Having never owned an impact driver does this sound like a viable plan? And if so do I need a basic one or one with huge amounts of torque, brushless motor and variable speeds? Any recommendations bearing in mind I'm on a tight budget - maybe £100 limit give or take a few quid? I'm told once you have one you'll wonder how you've coped for so long without one 😉
