In praise of the torque wrench!
Pale Rider
I didn't know that, none of my three bikes has four, food for thought:sad::whistle:.
"Most" might be overstating it, a Brompton only has one bolt.
The handlebars on mine moved a bit when the bolt loosened, but there was never any danger of them falling off.
screenman
I had a quill stem bolt snap at the start of a 50, that could have been interesting had I not heard and seen it go.
The 'bars came very loose on mine when the bolt sheared with no audible warning during a tour:eek:.
Fortunately I was travelling very slowly and about to dismount, but the additional accommodation costs whilst a fix was being devised could have bought a large box full of torque wrenches^_^.
Ajax Bay
East Devon
What's this got to do with torque wrenches? Did the bolts snap/shear because they were over (or under) torqued?
Or are these examples of what might happen if one over-torqued a bolt, and therefore designed to illustrate the criticality of some bolts.
Correct tightening bolts into carbon items is more assured with a torque wrench. Otherwise the benefits are debateable ^^^^.
annirak
annirak
Cambridge, UK
In nearly 60 years I have never owned one and never needed one. The repair you carried out could have been done without a torque wrench.
You dont NEED one. You just want one.
You're right. I don't NEED it. My other option was to take the bike to the LBS and ask them to work out the creak. They have far more experience fixing bikes than I do and might have been able to do it without the torque wrench. It saved me a trip to the LBS and taught be a bit about what happens when you over-tighten bolts. I'd call it well worthwhile at less than £25
I don't see why people get so wound up about not needing torque wrenches. They're the right tool for the job. If there's a fixing torque spec'd on a component, the correct tool to tighten that component is a tool that fixes the component to the specified torque. That tool is a torque wrench. It is not guesswork and an allen key.
I don't know how tight 5Nm is. I can guess--I tried to guess and failed. I WANTED the creak to stop, I didn't NEED it to. But I also didn't know if the creak was an over-tightened bolt or a dangerous pre-failure noise.
steveindenmark
I'm not wound up about it but I've never used one on a bike or motorbike. I doubt if I could guess pressure down to a couple of Nm but maybe some people have a better feel for it than others.
But you do sound a bit wound up. Now you have a torque wrench maybe you need to use it on yourself ^_^
Nigeyy
For a long time, I never used a torque wrench, and just went by feel. Then (and being honest here because I love good tools) I went out and got a decent one. I've used it more on the car than anything else, but even then if I'm in a hurry and assuming its not the engine block (don't want to warp the head thanks!) I tend to just wing it. Whatever you feel comfortable with is fine by me -and if you think you have (or have) no mechanical feel, I most definitely could see it being necessary.
While usually a bike not an investment of similar financial magnitude as a car, I can say I'd certainly hesitate buying a car from someone who claims they rebuilt the engine with no torque wrench versus a person who does (and of course there are other factors, but all things equal, etc). And maybe that says it all -if I was buying a really really expensive bike I'd be much more comfortable knowing the mechanicky person who worked on it used a good torque wrench.
The place where I'd most certainly want a torque wrench though is carbon fibre; wouldn't like to accidentally over tighten that, and if I had a CF frame (which I don't) I'd definitely be using a good torque wrench on that -my opinion is you need one then. So, even though I don't really use one that much, I'm giving two thumbs up to it :smile: Horses for courses......
annirak
annirak
Cambridge, UK
Ah, perhaps I misread the tone of your original comment ;)
Anyway, solved a problem for me!
