lulubel
- Malaga, Spain
I've been battling with this problem for a while, but haven't managed to fix it, so I hope someone else has some ideas.
I have a triple chainset on my new bike, Tiagra 9-sp triple shifters, Sora 50/39/30 crankset and Sora triple front mech. Ever since I fitted it, I've had the same problem. I can either have all the low gears OR all the high gears, but not both.
If I set the cable tension so that I can use all the gears on the big ring, the chain won't drop onto the granny ring. If I set it so that the chain will drop onto the granny ring, the chain rubs on the cage when on the big ring and using the 4 outer sprockets. This is with both limit screws right out, so they're not affecting it. I've also tweaked the height and angle of the cage, and what I've got now is the best I'm going to get there.
I've got a mega range cassette on it, so I've been using it like a standard double while I try to figure this out, but I've finally had to admit defeat and ask for help.
It seems to me that the indexed shifters aren't pulling the cable through far enough to access the full range of gears, but the only thing I've found that may be relevant to this is on Sheldon's site:
I can't see that there's a choice of cable attachment options, but I think I could put the cable through on the other side of the bolt. This would put it closer to the pivot, so I think it would make the cage move further for the same amount of cable pull. From what I can see, this would be a "bodge", though (and none of our other triples are set up this way), and I'd rather get it working properly without having to set it up in a way it isn't meant to be set up!
Any suggestions?
Some newer front derailers are designed with a choice of two cable attachment options. If the cable is run on the outside of the anchor bolt, away from the parallelogram pivots, the cage moves less far for a given cable movement, providing a lighter action, and easier fine trimming.
If the cable is run on the inside of the anchor bolt, toward the parallelogram pivots, the cage moves farther for a given cable movement. This is often necessary to provide correct functioning with indexed shifters.
Any suggestions?
