Install XP without DVD.
lozcs
Wychbold
Any geek advice please?
I've got a Panasonic CF-19 with a BIOS password and HD locked.
It's running Windows 7 but I need to put Windows XP on it.
It has no CD drive and is locked to boot from HDD. Not sure if it boots from USB but can't change the BIOS to check.
Tried to put HDD in another PC to start XP install there but immediatly promted for HD password.
It has a f12 boot from network option so I looked into Windows Deployment Services on an available server I have here but XP on WDS look like a nightmare to create necessary WMI and really haven't got the time just for one install.
Thought I'd check before this laptop sits on the shelf...
Any ideas?
Davidc
Somerset UK
Not sure if it's quite like your problem, but I dealt with a locked down Win XP machine needing Win 2000 on it by copying the XP CD onto the hard drive and then installing XP from the HDD copy.
That was in about 2004 and might no longer be applicable. ( I bet disgruntled ex employees locking things before leaving are still around though).
MrJamie
Oaf on a Bike
Why can't you change the BIOS settings? That seems your main hurdle, maybe you need to reset it so you can get into it and change boot settings.
lozcs
lozcs
Wychbold
Might have a backdoor password like this model http://www.ehow.com/how_7530118_unlock-toughbook-cf29-bios-password.html
Could you use an external CD/DVD drive ?
tried that password already - boot order set to HDD first so even if is able to boot from USB not able to set.
I can't find any links to reset BIOS on CF-19
If you disconnect the mains, main battery and the cmos battery it should loose the lot including the password. There is a picture of the cmos internal battery in the manual http://tim.id.au/laptops/panasonic/CF-19FHGAXxM.pdf , see coin battery in the diagram of the motherboard.
I'll have a look thanks......
Mile195
West Kent
If the boot order is set to HDD first, you could format the hard disk, or delete everything in the root directory. It won't then be able to boot from it, and should theoretically move to the next drive on the list. Of course, if the boot order has been amended so there is no secondary boot drive this does mean that it'll render the laptop virtually useless.
lozcs
lozcs
Wychbold
Thought about trying that... But before I did I thought maybe there is a way to partition the drive and add setup files so next boot allows me to just run XP setup from command prompt..
lozcs
lozcs
Wychbold
Anyone know if there is a WIM file I can add to my WDS server that would allow me to boot laptop and run command prompt? Maybe then run setup direct from external USB drive?
lozcs
lozcs
Wychbold
If it doesn't work I could easily setup WDS server to put 7 back on - just seems like a whole load of hassle to setup WIM files for XP via WDS
paul04
Have a look here, somebody else was asking the similar question
http://forum.notebookreview.com/panasonic/560412-help-cf19-k-bios-problem.html
Instructions
1. Press "Power" to turn on your Panasonic Toughbook.
2. Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password.
3. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
http://www.techstation.org/forum/topic/178065-panasonic-toughbook-help/
lozcs
lozcs
Wychbold
Instructions
Thanks. I'd already tried that password - didn't work.. It's a c-19 so perhaps different...
