david1701
- Bude, Cornwall
My fileserver is pretty normal I guess, its an ancient gaming rig (I built it up with a vista BETA first time round) thats been repurposed a few times and now it lives with a 1tb OS driveand 3x3tb drives for storage.
I had the storage drives and the os drives/optical (removed as I'm using it elsewhere atm) on the two different sata busses (90% sure they're diff busses as they're a few inches apart and ones 4 ports the other 2).
Sometimes if I reboot it then it gives me a disk error because it can't find the OS drive (I can't find it in the bios either), I pulled the drive and dropped it into a caddy where it reads fine, back in the machine and it boots fine, so I write it off as a weirdness and keep going. A spell later I need to do another reboot and same issue, leave it 10 minutes grumpily and it boots.
tried using both busses (as bios always reads the file drives so I had to assume that that bus is fine) and I only have one sata power cable in there (told you it was old
) but I tried both ports.
All I can come to is some crazy temperature issue so I've cranked the fans up a bit and the case isn't getting hot at all :s (touched the drive to see how hot and its warm but not 70+ or anything)
) but I tried both ports.All I can come to is some crazy temperature issue so I've cranked the fans up a bit and the case isn't getting hot at all :s (touched the drive to see how hot and its warm but not 70+ or anything)
