Internal Gear Cable Housing Routing
Hi Folks
need to replace my rear derailleur inner cable housing/routing liner sheath (whatever the name for it is ^_^)
what is the standard size for this?
i measure outside diameter at 2mm
bike is nothing fancy, 2021 cannondale synapse
anyone any links to the product?
something from amazon would be good, would like to be riding this weekend if possible :becool:
thanks
Paulus
Barnet,
Hi Folks
thanks
It's called an outer cable, the actual cable is called the "inner"
Make sure you buy a replacment gear cable outer and inner.
NorthernSky
ok, i think i get it now , the lining is just to help you route the new cable through the frame? it's not actually needed but makes things a hell of a lot easier...
i pulled the old liner out in my haste but i think it was causing issues anyway.
