Adjusting front mech (internal routing)
livpoksoc
Basingstoke
I need to adjust the tension on my front mech as the upshift to larger cog isn't smooth, sometimes taking a lot of push on the shifter, and occasionally am finding the chain will jump down from big to small.
It's a two by, GRX with internal routing, so I can't see any obvious barrdl adjusters to make the finer trims I am used to on a 105 set up.
Any guidance is greatly appreciated.
richardfm
Cardiff
Can you see the derailleur start to move as soon as you begin to change from the small to big chain ring?
If you can, and even if you can't, you may find that you just need to slacken off the high limit screw a smidge.
livpoksoc
livpoksoc
Basingstoke
adiemla
(Due to advancing age and knee osteoarthritis) I recently purchased a used GRX equipped 1x11 ebike at a good price and am now toying about transforming it into a 2x11. Bit puzzled about the internal cabling (inner and outer). Does the GRX front derailleur have a inbuilt outer cable stop?
