Is there an app...
outlash
also available in orange
or a piece of software where I can work out a specific route and it'll calculate the distance? I'd like to plan out a ride and see how many miles it'll be before I set out.
TIA
Tony.
ACS
Matt1705
Redditch
There's a website (think it has an app too) that works as a cycle routes planner. Can remember the name so just Google 'cycle routes planner'
Hope this helps :-)
Phil_bucks
Buckinghamshire
Mapmyride does exactly that on the iPhone & web
The CycleStreets app is reasonable.
Type in the start and destination and it will give you fast, quiet and medium routes, choose which one you want and then either use it as it stands, or as a base for your own route.
outlash
outlash
Thanks :smile:, I'll give some of them a go.
In the old days we used to look at a map. In fact, I still do. Anything wrong with that?
Not at all, but if I want to say do a 10 (ish) mile ride how would I work that out on a map?
Tony.
Rob3rt
Man or Moose!
Manchester
IMO, RidewithGPS, is by far the superior route planning website out of Mapmyride and Bikeroutetoaster. The former is awkward in the file formatting (at least it used to be, maybe they rectified this farce), the latter has the shittest UI conceivable!
Tony.
Using a bit of string, a ruler and the scale given in the corner!
