AlanW
- Not to sure?
I've decided to opt for the Jagwire Sealed cables on the new Ti build, but straight away I've hit a problem and its makes no mention of it on any of their instruction videos or the very vague paper instructions either?
They state that you should fit the "silver brass end cap" to the end of the outer brake cable that fits into the the shifter body as its helps keep the liner in place. But the end cap will not fit inside the R8000 Ultegra shifter body, the hole in the body just isn't large enough to accommodate it??
So does it need the end cap, because where can the liner go, it has a flanged end so it cannot go inside the outer cable, and it cannot go in the other direction?
Anyone else had this problem and if so how did you overcome it?
