Jammed Mortice Lock.
Smokin Joe
The lock on the back door to the garage has jammed shut. I can get a jigsaw blade in the gap 'tween door and frame, does anyone know if the tongue is likely to be hardened or should it cut easily?
MikeG
Suffolk
If it is a British made lock, or anything to British standards, you've got no chance of cutting it. If it's a bit of cheap Chinese junk.........well.........give it a try.
How does a lock jam shut? What happens when you insert the key?
Cycleops
Accra, Ghana
One of these might be the only answer but if you do make sure this chap isn't on the end of it.
slowmotion
Quite dreadful
lost somewhere
Salty seadog
Space Cadet...(3rd Class...)
Depends which end.
classic33
Leg End Member
A 1mm steel cutting disk can cut pretty much anything, especially over-priced bike locks.
https://www.screwfix.com/p/metal-cu...ck/2585v#product_additional_details_container
Locksmiths just drill out the key mechanism by aiming a (say) 8-10mm HSS drill right into the key slot. It's really fast and doesn't louse up the door or frame.
Some locks now have hardened steel plates to stop that. Notably Yale & Chubb.
@Smokin Joe, five lever lock?
Does the key stick at the same point in either direction. Are all keys for the lock in one piece.
