- Glasgow
Hi all!
My Joe Blow Max HP is broken: it might have been my fault because I didn't open a Presta valve properly, the pump is now deflating instead of inflating.
Don't know if this is relevant, but it does the same on the Schrader side of the head too.
Thinking it might have been the rubber seals, I purchased a rebuilt kit.
After changing the rubber seal, that looked worn, matters stayed the same.
So I did a search, found a You Tube video that suggests the check valve is defective.
I removed it, there seems to be nothing wrong with it, although now I can't seem to manage to tighten it properly again
Anyhow, questions:
can someone tell me what the largest o ring in the rebuilt kit is for?
If I manage to purchase that check valve (seems to be out of stock in most outlets) would that solve the issue, or could it be something else?
It would be a shame to have to bin the pump, it is only 2 years old, used about twice a week: is this an acceptable lifespan for a middle of the range pump?
Thanks very much for your help!
Pat.
Anyhow, questions:
Pat.
