Joeblow pump
Pinhead63
Hi, having trouble attaching the pump to the valve (schrader) on the front wheel , as I cant get it between the spokes on my Brompton managed to squeeze it onto the back wheel with some difficulty. Is there some sort of attachment I could use to connect the valve and the pump.
weareHKR
Strange, you still should be able to use the Joeblow?
HERE
And HERE
the_mikey
When I had a Brompton I used a JoeBlow pump, it was a bit awkward but not impossible to use. I also carried a Topeak mini track pump in the saddle bag which was much easier to use with the Brompton.
Fab Foodie
Kirton, Devon.
It's doable, a bit of a fiddle, and it works better from one side of the wheel than the other (I have a 6spd rear wheel and a SON Dynohub front so spoke spacing may vary).
I use one all the time on my B.
