Just got myself a bargain right place right time.
DEFENDER01
Essex
Due to knee problems arthritis getting worse i have been using my cycle less and less as i now find hills are getting steeper.
Been thinking about an electric bike but couldn't justify the expense for my use.
At £100.00 and only done 5 miles i couldn't let this one pass.:rolleyes:
steveindenmark
At that price, if it lasts the year you have got a bargain.
Enjoy it.
Pale Rider
Basic Chinese folder which are not such bad value at the usual price of around £400, so £100 is properly cheap.
Decent size battery, which some don't have.
The little wheels means it will climb remarkably well.
Overall gearing can be a bit low, so you might have to spin like Froomey to get any speed out of it.
DEFENDER01
DEFENDER01
Essex
Yes been out a few times and i will use it more than my other cycle as i now can cope with the hills and still exercise my legs.
Only problem is the high gear puts the chain at an angle that throws it off the crank sprocket so i have set it not to go that far over.
Its a 6 speed cassette but really only 5 now not that its too much of a problem but i guess it would be nice to have it.:rolleyes:
Certainly is nice to be able to tackle hills i wouldn't normally attempt.
DEFENDER01
DEFENDER01
Essex
As i never got a manual with the cycle do i need to remove the battery or can i charge it on the cycle. ?? :rolleyes:
DEFENDER01
DEFENDER01
Essex
Well just an update.
Having now had a chance to give this cycle some mileage i must say i am very impressed with its performance.
It is a joy to ride and i now find myself using it more as i was finding myself using my M T B less although i still intend to ride it sometimes.
As people have said if e cycles get you out riding again they are a good thing i cant argue with that.:bicycle:
{ Found this little snippet about Powacycles. }
The PowaCycle brand stands for high specification, yet reasonably priced, electric bikes from a professional company. We are part of Ultima Networks PLC - www.UltimaNetworks.co.uk - a dynamic company quoted on the UK stock market and highly committed to energy efficient products and technologies.
By offering a range of 6 gears, PowaCycle Electric Bikes reduce dependency on motor power to tackle slopes, and achieve a decent pace just by pedalling. As gears make pedalling easier and help riders achieve pace, users are encouraged to full exercise benefits from cycling. As riders get so much more from pedalling, less battery power is consumed, effectively raising the distance range in the assisted power mode. Our PowaCycle Electric Bikes are designed to help riders make the most of their own energy, providing plenty of extra power on demand.
Sheffield_Tiger
Hmm..looking at that, the battery looks a fairly commonly used type too; when the time to replace it does come round (and it will)
Should be easy enough to source
DEFENDER01
DEFENDER01
Essex
I have heard people say they are still running on the same battery after 5 years.
Hope so as i have seen the same battery priced at around £300.00 :wacko:
Pale Rider
Pah, you're lucky, batteries for Bosch and Kalkhoff ebikes are up to £700.
Battery longevity comes down to two things, cell quality and use the battery is put to.
You wouldn't expect top quality cells on a battery for a budget Chinese ebike, although they may be branded, so all is not lost there.
As regards use, running high power motors thrashes the cells and shortens their life.
You have a fairly low power motor, so it won't be giving the battery a hard time.
Cells last longer if they are used regularly, and used from close to full rather than close to empty.
Charging after every ride - unless it is literally only a mile or two - is best for battery longevity.
On t'other hand, a full charge stresses the cells, so they are best not left for long periods of time fully charged.
No problems if you use the bike regularly, but were you going to stop using it for a while, the battery should be left part charged - roughly half to three-quarters.
Saluki
World class procrastinator
I am keeping half an eye out for one, for my upstairs neighbour. She says, now she's turned 70, that riding her Apollo XC26 is getting a bit more like hard work.
That's a stunning bargain you've got there @DEFENDER01, well done. I hope that I can find a bargain like that for Averil upstairs.
