I will be buying a brand new brompton, after cleaning it, can I protect it by waxing it like you would a car
Smear anything chromed (brake nuts and bolts, seatclamp bolt with Vaseline in winter, otherwise the salt will make them rusty in no time. The wipe if ott again in spring.
It's a Brompton - hopefully he'll not be locking it up anywhere.Thieves like shiny bikes. There are pros and cons to everything.
Colinite 476 wax is as good as anything at protecting & 'shining' anything. It's available pretty much everywhere & cheap enough. Not easy to work with when it's cold but it should take half an hour to do a bike frame tops. You can spend a hell of a lot more if you want concourse super glossy but I really cant see the point, it's the protection you need.
It will be warm in the house so it can be polished there, thanks for the advice
Paint sealant is not a wax, it last longer than a wax does and is very easy to apply.
