oldandslow
Probably better if we don't go round this loop ad nauseam, but that's the non-sequitur that I was trying to highlight. I've been in a number of falls, mostly before helmets were invented, where my skull and brain were fine, but a cardboard or even paper helmet would have been wrecked. This illustrates that damage to the helmet is evidence of the degree to which the stresses experienced exceeded the levels for which the helmet was designed. For paper or cardboard, that's not much. For real helmets, it's intended to be rather more, but you still don't know what proportion of the collision forces were absorbed. It's absolutely certain that your skull did some of the work because, before helmets, it would have done all of it, and you'd have survived most crashes.If the helmet is badly damaged but the skull is not after a collision with the ground then that is evidence of effectiveness.
What limits? They are not designed to be indestructible but are designed to take the brunt of the contact and limit damage to the skull. In fact I understand it is recommended that a helmet is changed after a severe hit whether damage is obvious or not.
A helmet is not going to prevent all injuries and is not designed to.
You need to look elsewhere than helmet damage for evidence of the degree to which the skull and brain were protected. You can have some remarkably bad crashes and survive effectively unscathed even without a helmet. So it must be possible to destroy a helmet in a crash that you'd have survived without one.
This isn't necessarily an argument against wearing one, but it is a plea for realism in assessing the benefits.
