KMX Gears 3x8=21 ?
Andrew1971
Northallerton
Hi all
Got a little problem with my KMX. I have taken the two top chain tube's off because they were noisey.
So i take it out for a spin put it into 8th gear it was noisey me think's rear deraileur need's adjustment
I get home it's the chain rubbing on the frame. No matter i much i adjust rear deraileur it will alway's rub on frame in 8th gear only. So it rub's with or without chain tube on. Small design flaw !!.
So i can't use 8th gear hence 3x8=21:angry: Has any one else got a simular problem with their KMX:sad:
Many Thank's
Andrew
Lanky
I would be thinking of a trip to Cowleys bike shop. Has it always been like that. :sad:
Andrew1971
Andrew1971
Northallerton
Yes. as iam getting better i have been getting into the higher gears that's when started showing up.
I have a couple of idea's now i had time to think about it.
@numbnuts how close is your chain to frame.
I bet i have the dodgy one. Look's like phone call to KMX and just fitted new tire's too and some other mod's too. Or fix it myself.
Many Thank's
Andrew
Many Thank's
Andrew
It's very close, but it's not rubbing, well the paints not marked
Andrew1971
Andrew1971
Northallerton
A little update managed to get her a lot quiter but still rub's.
I going to put some tape over the mark on the frame and see what happens.
Many Thank's
Andrew
e-rider
Banned member
South West
reading this post it's hard to picture exactly where the chain is rubbing, but, it could be that the frame was designed for 7 speed cassettes and the 8 speed is just 1 or 2mm too wide - you might be able to adjust it out by playing about with the rear hub axle configuration
it does sound like the design of the frame isn't the best as well
Andrew1971
Andrew1971
Northallerton
Hi All
Some picture's
The bottom pic is of chain hiding the mark it made on the frame.
That's the result from the chain rubbing even more noisey with a 11t put 12t to stop it and did not.
Many Thank's
Andrew
