xilios said:
Thanks for all the tips, we will have to go and check out the EEE 900pc but are concerned about the size. We would also like to use it at home on occasion not only on tour.
Our budget is about 500 euros, we wouldn't like to take anything more expensive than that along on tour.
So that leaves out the nicer toys like the Panasonic R6, Macbook Air, and a few others
I bought the Asus for a specific work function, to take stock at work on to a spreadsheet. I have the Linux version and being non-technical have not bothered to try and change to XP. The Open Office software supplied works very well, it's probably better than MS Office and any document you create can be converted to an MS file - though I have found Office 2007 is not very friendly towards Open Office - no surprise there!. I'm not a techie but I understand the Asus has been designed to work with Linux and Open Office and so wouldn't want to change this especially as XP has become so slow and cumbersome. The Linus / Open office seems much faster than XP /MS Office.
On tour you may want to use the laptop under a wide variety of conditions, I'm using the Asus outside and in glasshouses across 12 acres of plant production and it performs well in all weathers. The screen is very readable in bright sun, unlike my expensive full size notebook. I walk around with it in my left hand all day without a problem. Using it for data entry is a bit like giant texting.
In the office, in your case at home, it responds very well to plugging in a wireless mouse and keyboard and being hard-wired to a full size screen. Typing on the small keyboard takes getting used to but is OK. Plugging in a USB sim card gives you web access anywhere you can get a mobile signal. Flash drives are instantly recognised giving plenty of back up opportunities.
Web connection is easy though the automatic interface set up (whatever that is!) is a bit slow. Once connected the connection is always very stable. The wireless connections are very quick.
I would thoroughly recommend this machine for touring. It's true battery life is short - 2.5 hours on mine - but you can get an extended battery which lasts 4.5 hours. This battery only comes in white and looks a bit naff on my black Asus. it's also bulky and sticks out the back of the machine. Recharging the standard battery or the extended battery is fast. The extended battery is £50 and does take a bit of tracking down.
Asus have stolen the lead in this area. Buy one, you won't be disappointed.
