Lifeline Brake Cables / Shifter Cables
Loch side.
The difference in quality between brake cables is not all that obvious. Even expert mechanics have a difficult time judging good and bad cables and in the absence of knowledge, price always win. I can't say if those are good cables or bad cables but they are cheap.
Cables are made up of wound strands of high-tensile wire. If you cut a cross section and look at it through a magnifying glass, you'll see it as a daisy shape. This shape is not desirable since it is quite rough, especially on the brake where high tension is used and we all know that the difference between great brakes and poor brakes is a rough cable. Quality cable thus undergoes some other processes to make it smoother - it gets drawn through a die to flatten the daisy petals and create a smoother outer circumference. This adds cost but makes the cable a pleasure to use and gives it longevity since it doesn't saw through the inner radius of a bend in the housing. One step up from this would be a coating but here's a catch. Teflon is not suitable. It is too soft. Black coated cable is touted as smoother, which it is, for a while. After a bit of use the Teflon or PTFE is rubbed off and the sawdust gums up the housing instead of reducing friction.
So far the only coating that works is Shimano's polymer, which ironically coats the smoothed-out cable in a rough, lizard-skin series of microscopic ridges. This is very expensive.
Look for a cable that is at least stainless (never galvanized) and at least flattened. If you have Dura Ace stuff, treat yourself with the polymer cable.
Finally, never replace a cable without replacing the housing. Housing wears out on the inside radius and creates friction.
Thanks yellow saddle. Informative posting as always.
Hampshire
I've been using them (and the brake pads) on various bikes for a couple of years, they're fine IMO and very good value.
Each to there own, but I've never found the need to change the outers unless they're really old and cracking on the outside.
Loch side.
The outside of the outers is exactly where cracks don't matter.
Brake cables have three parts 1: An inner core of nylon. Just a nylon tube. 2. A steel mid-section made from steel ribbon wound into a tight helical cyclinder. A protective outer. Since brake cables operate under high tension and the cable feeds around corners (especially the rear), it is susceptible to wear on the insides of those corners, often filing right through to the steel. Although it still works and is still perfectly safe, new housing makes the experience so much better. No grittiness, less friction and better one-finger control. A workshop should always replace both but DIYers can of course do what they like.
