twentysix by twentyfive
Clinging on tightly
- Over the Hill
New taps.............
A sure way is to buy some brick cleaner from a builder's merchant. Wear rubber gloves, apply with small paint brush and wipe with fine wire-wool. Rinse thoroughly!! Don't use on plastic baths but OK on vitreous enamel WHB and toilet pans. OK on chrome taps. Been doing it for years.Thank you for all your replies. I was looking for some kind of gel to put on and leave but the plastic bag idea with vinegar/lemon juice or maybe limelight banded on and left overnight sounds like the solution, I will give it a try.
I always thought living in Yorkshire was the issue. I live in a small village near Tadcaster which is built on limestone therefore the water table runs through limestone and that's what causes the build up.I solved my limescale problem by moving from Hampshire to Sheffield.
Damn - I was just about to suggest a one-way rail ticket to Yorkshire!
The difference in the water was one of the things I noticed very soon after moving here. When people from 'daarn saarth' stay with me they comment on how nice the tea tastes, and I always notice how bad it is when I visit them.
As mentioned previously!
Both of you can stick your postcode in here to get a detailed breakdown of your water quality.
It would be interesting to compare Hebden Bridge and Tadcaster. Here's the report for my bit of Sheffield:
Calcium 5.45 - mg Ca/l
Magnesium 2.4 - mg Mg/l
Residual chlorine - free 0.31 - mg/l Cl2
Residual chlorine - total 0.41 - mg/l Cl2
Coliforms 0 0 no/100ml
E-coli 0 0 no/100ml
Aluminium 19 200 µg Al/l
Colour 1 20 mg/l Pt/Co Scale
Conductivity 173 2500 µS/cm
Fluoride 0.05 1.5 mg F/l
pH (Hydrogen Ion Conc.) 8.1 6.5 - 9.5 pH Units
Iron 20 200 µg Fe/l
Nitrate 2.126 50 mg NO3/l
Nitrite 0.009 0.5 mg NO2/l
Sodium 28.2 200 mg Na/l
Turbidity 0.12 4 NTU
Copper 0.0199 2 mg Cu/l
Lead 3.2 10 µg Pb/l
Where there are 2 values, the first is the measured amount and the second is the legal limit.
Here you go ...Both of you can stick your postcode in here to get a detailed breakdown of your water quality.
E-coli 0 0 no/100ml
Iron 20 200 µg Fe/l
Lead 3.2 10 µg Pb/l
