Luegolover
- Sunny North London
Hello,
I am putting together a Chinese sourced carbon bike which has internal cabling. I am not sure if I should use a liner or not?
So above you can see the underside of my frame with the cable routing guide in place. On the right the hydraulic cable for the rear brake is visible and next to it are two white plastic lines that I will use to feed the cable through. So, should I just run the wire inner cable the length of the frame or should I feed a liner in and then run the cable through that?
