If you have a longer set of cranks already, you might be able to have them re-drilled.
I've had two pairs drilled down to 150mm by https://highpath.co.uk/ and have been very good.
Cranks need to be of solid construction (ie not hollow cranks)
Welcome back after 8 years https://www.spacycles.co.uk/m2b0s109p3531/SPA-CYCLES-RD-2-Road-Cranks
Spa Cycles have these (130mm BCD double) down to 165mm crank length. After that they use 110mm BCD for the XD-2 touring crankset, down to 160mm length.
If it's a triple than they have 160mm chainsets at excellent prices (square taper).
