Looking for Best Budget Bike With These Specs
Crevice
Hello, I am 53 and 6'4" I'm looking for something that is inexpensive but reliable the has disc brakes (preferably hydraulic), prefer a 1x drivetrain but that's not a deal breaker and something that would be considered a hybrid or maybe gravel/smooth trail bike. I would prefer an upright position bike or something that's easy on the neck/spine. Any suggestions?
AndyRM
XOXO
North Shields
Alex321
South Wales
"Inexpensive" can have very different meanings for different people.
Do you mean under £300? Under £500? Under £1000 (starting to get a reasonable choice)? Or something else?
A flat bar right hybrid with your spec will be cheaper than a drop bar gravel bike.
If flats, take a look at the Whyte R7 range (you’ll need an XL). They cost £700-1100 new I think. If prepared to go second hand, it’ll be cheaper but your preferred spec of 1x and hydraulic discs is pricy.
There might be a sub £1k Boardman hybrid but the availability is v sketchy
Crevice
Crevice
Yes I should have mentioned that. A flat bar would be common for that riding position I would think.
Or a well fitting bike, possibly with an angled stem.
If you have issues with your neck / spine which can’t be resolved with stretching, pilates, core strengthening etc, make sure adjustments are possible with the bike you choose.
What’s your budget?
You’ll be lucky I’d think, discounts are few and far between as stocks are so low.
Second hand might get you a better deal
Ah, you’re in the US? Forget Whyte and Boardman then!
I’d say that looks very basic, suspension on cheaper bikes is usually heavy and poor quality. Stick to rigid forks unless seriously off roading.
Probably ok for light occasional use
Bike specs. :okay:
Crevice
Crevice
This is the main page for Hybrid bikes and they seem to have some decent prices, better supply than most and they are getting stock in as well. The bike I linked earlier was just an example. You're right though, with rigid forks would be better and I would guess cheaper. But that had hydraulic disc brakes as well. It was in stock this morning. Not that I was wanting that bike though, that's why I'm here. :smile:
Crevice
Crevice
Not sure how to go about a used bike. If you folks could provide some suggestions on used offerings as well that would be good to look at.
