Pale Rider
The gearing on my trekking bike is too high and I would like to know what practical difference a smaller front chain ring would make.
Current set up is an Alfine 11 hub, 20t rear sprocket and 42t on the front.
The rear sprocket is as big as you can get, but first still equates to about 7mph with reasonable cadence - it's too high to grind up really steep hills.
There's a good choice of smaller rings for the front: 40t, 38t and 36t.
How much difference will dropping two teeth make?
Working out gear inches doesn't help me because I don't know enough to interpret the results.
I'm no speed merchant, so there's a bit of headroom at the top end to work with - I normally bowl along in sixth or seventh.
All comments - apart from lose weight and get fitter - appreciated.
