M.O.T. roulette - place your bets
Your MOT isn’t a bad thing. Over here in Canada it’s up to the owner to take care of his vehicle and be sure it’s safe. This results in a lot of stuff rolling around on our salty roads with little more than brown lace for a floor. Mechanics are supposed to stop unsafe junk from leaving their shops but this does nothing about vehicles cared for by home mechanics. I‘ve driven a vehicle for over a decade and a half without it ever seeing a shop, just did my own service and carried on.
It’s even worse south of the border. If a mechanic points out your car is unsafe you just drive it away. I’ve seen badly crash damaged cars belting down the interstate on totally bald tires at 70mph without a care in the world. Kinda makes you want to scurry off home to hide under the bed.
Wow. TBH the MOT is quite strict in the UK (unless it's a dodgy one or ghost MOT). If done at a 'dealership' there is the 'upsell' - if anything is looking a bit 'worn', it will be an advisory - e.g. the dealer put on my MOT last year that one tyre was near the legal limit. The health check video at the time, and the one that was done 6 months later when the car had an aircon recharge, showed the tyre at 4mm. I replaced both rear tyres last month as they were coming upto 5 years old, but still way above the limit.
I usually use my local independent as they are honest and don't overcharge for parts/fitting.
13 rider
leicester
I watch a YouTube channel "south main auto" based in New York state the rust belt as they call it ,the rust on some of the vehicles is unbelievable and not them but other shops let them pass state inspection 😮
fritz katzenjammer
Der Ubergrosserbudgie
Yeah… back in the seventies it wasn’t uncommon for rust belt cars to sag in the middle when it was time for the scrapper.
My uncle had a Datsun 110 back then, he was sitting at a railway crossing one day and the floor blew in when the express train passed. My own Datsun 110 broke in the middle on the expressway one day. I hit the brakes and the front wheel came back and hit the floor. Both cars were retired.
I use the garage round the corner, because its a 5 minute walk back home!
Mine is about 15 minutes. I'm not so sure how many years they will still be around, mainly as all of the mechanics and staff are knocking on quite a bit and it's a family business. They are very busy though.
Milzy
Standard wear and tear. CV joint is a 'bigger job' I won't touch - needs some big 'spanners'. Drop links are super cheap and generally easy to remove.
It was track rod ends last year for MrsF's car (worn rubber) and it's ball joints this year as the rubber has split.
Damn I almost posted split rubber.
I'm assuming the garage has been fitting the fuel pump this morning as I've just had email warnings from Vauxhall Connect that my van has thrown an engine fault, stop the vehicle, and a gearbox fault. They have probably upset it running the diagnostics.
Van is back, only cost was fuel treatment and half price diagnostic for the electrical fault, that didn't appear. £94.
MrsF's now in for new tyres on Friday, but they wanted another £500 for new control arms and a MOT Test - my usual garage have said about half that. Will be even less if the ball joints are good as they will fit a new boot kit.
MrsF's Qashaqi is in for MOT and ball joint boots/control arm (if joints worn). It's 14 years old so a bit of perished rubber is all I'm expecting. Pads all done earlier this year and it's sporting new Cross Climate 3's on the front.
Brilliant tyres. Considering them for the van.
The 3's are even better in the rain. Spendy though. £340 for two. Got 2's on the rear.
Car has failed on the two ball joints as expected but there is nothing else listed, no advisories. All it says is the seal no longer stops ingress of dirt. Hopefully it's a cheap 'boot' job, but no big issue if new arms as that means the other 'bushings' are 'new'. I didn't even know there were 'boot kits' until the Mechanic mentioned it when I booked it in. Unfortunately, MrsF's car has failed on various front suspension 'seals' the last three times. Split CV gaiter, then needed new track rod ends last year (perished rubber). TBH it's 14 years old and this is to be expected. No corrosion issues or anything else.
Fastpedaller
Norfolk
Our Ford had the same lower arm a year ago. I bought a boot kit from Ebay (seemed good quality), but the difficulty was getting the new ones to stay on! the originals were clearly 'glued' and there was no ridge or groove for a method of securing. As the MOT tester said the pattern ones may only last 1 year, I put new boots on (took some time) after carefully cleaning with area with panel wipe, and put some copper wire around the edge and twisted it to secure. When I returned for MOT, one had popped off, and the guy said superglue is your friend. Another dismantle and clean, and secured with superglue it passed. A year later the superglue had failed. They put new lower arms on (I really didn't want to try again :sad: ), and said they are Borg and Beck with a 2 year warranty. I looked at it when I got it home, and it looks like it's already oozing out grease. I'll decide whether to look again and take it back to them or monitor it and wait until next MOT.
Could be overly packed with grease, so I'd wipe it off and monitor. I had this with a new CV joint - grease splattered out over the wheel at first, then stopped. There are specific boot kits for the car, so I'll see. Don't mind if it's a new arm as it means the other bushings are new and aren't going to go at the next MOT. The test has not mentioned any 'play' so a boot kit may be on the cards. Last year's MOT mentioned failed rubbers and 'play' for the track rod ends.
Fastpedaller
Norfolk
The old ones failed the MOT because there was some grease oozing out (suggesting dirt could get in?), and they aren't meant to be 'customer filled'
