Making a rear light
musa
Surrey
My lights Which are Cree torches as been reduced to one. One has just stopped so I bought new lights.
Does any know how to turn the torch into a rear light. I first initial though was to buy red acetate sheet and cut a piece and place on the lens? Suitable?
PpPete
Chandler's Ford
Putting a red filter over a white light is a waste of time.
  • They end up looking pink not red
  • Red LEDs are way more efficient users of battery power than white ones.
Just get one of these. http://www.chainreactioncycles.com/Models.aspx?ModelID=42472
sidevalve
Can't see any reason why not unless it's insanely bright and pointed at following drivers/riders eyes. I'd make sure it's well stuck/fitted in place though as a white light to the rear is illegal [and pretty useless as a rear light] unless you enjoy arguing with everybody else on the road.
02GF74
why bother making a rear light weh you can pick one up on ebay for £ 2 probably.
white LEDs are not white light but blue LED with yellow phospor that appears to the human eye as white light - take a look at the CREE LED when truned off and you see the yellow phospor - not sure how well they will work if shone through a red filter - you really want to be using red LEDs.
TheDoctor
Europe Endless
The TerrorVortex
£2? That's verging on costly for rear LED lights these days.
The ones I got from Poundland are pretty good - certainly way better than the Vistalites I paid a tenner for before CC was a gleam in little Admin's eye.
musa
musa
Surrey
I'm aware red LEDs are preferred. Just wanted to see if it was worth using Thr light but I'll keep it as a backup ( if I get a new ride I'll relegate it to that instead)
Thanks for the replies anyways
Night Train
Maker of Things
I converted some led torches to rear lights.
I had a broken lorry tail light in my workshop so I cut out some round discs of red prismatic lense and glued it to the business end of the torch with Araldite.
Works fine.
I have one permanently fitted on my Brompton, and my Hungarian folder, and my Ratrike. Arch also has a couple.
Here is the one on the Ratrike, it is set up as a brake light.
It is a waste of time to convert them really, as a perfectly acceptable rear light is so cheap to buy, but it was good fun making them.
Also I only use them in conjunction with a legal rear light anyway.
