Man Up or Play It Safe?
Jezston
Jezston
London
Every day, I go through this roundabout on my commute - basically following the Ashbourne Road:
http://maps.google.co.uk/maps?f=q&s...9075,-1.504108&spn=0.001167,0.002299&t=h&z=19
At the moment, I'm scared of it, so I mount the pavement and use the pedestrian crossing!
Am I right to do this, or is it probably a lot safer than I think, and I should be able to ride across it?
downfader
extimus uero philosophus
'ampsheeeer
I take it you mean you walk the crossing, just to play devils advocate in advance :blush:
There are a couple like that here. One I simply will not ride on - its been proven bad enough for drivers so I tend to walk it. Another is just as big but far less busy and frantic so I ride around it no problem.
Sometimes its just a call you have to make.
downfader
'ampsheeeer
I take it you mean you walk the crossing, just to play devils advocate in advance :evil:
downfader
'ampsheeeer
I take it you mean you walk the crossing, just to play devils advocate in advance :ohmy:
I have one I don't ride round in a particular direction the way home, as it's a shooting gallery, and I found out to my cost in December 08. I either avoid it, or ride from an alternative direction.
HobbesChoice
Essex
Hi Jezston. It probably doesn't put on much journey time for you to carry on with the route you're taking if that makes you feel comfortable. With my commute I just want to enjoy it and so I take the routes and risks I'm ok with. One day you'll find that roundabout looking a LOT quieter than normal (school holidays? different journey time than usual etc) and you can try it out then to see if you're happier on it or off it?
HobbesChoice
Essex
HobbesChoice
Essex
