Marathon Plus meets its match
caesar
Sudden rear (fortunately) tyre deflation yesterday while riding my Brompton on Dorking High Street. Very unusual to puncture these tyres so was intrigued as to what might have caused it. Was a little shocked to see this:
And after backtracking a little way, I found the likely culprit:
I'm sure it was dropped accidentally but I will report it to the police in case they have had similar reports. Still to come is the thumb-blistering fun of changing tyres. At least the old one should be easier to get off than usual as it is cut in half from bead to bead!
Herzog
Swinglish Mountain Goat
Wow, you must have caught it perfectly!
uphillstruggler
Half way there
that looks nasty, were you riding on paving slab type path or tarmac? would have thought that if it was flat on the ground, surely the tyre would have gone straight over with no issues.
C
caesar
Tarmac road. It was lying flat when I found it, I guess the front wheel kicked it up perfectly!
Sara_H
Blimey!
I did have a puncture in my marathon plus once, it was a MAHOOSIVE thorn. I also have slime inner tubes so was saved from a repair!
Dont think a slime tube would have saved you though!
C
caesar
It made a noise but didn't sound like a puncture. I felt myself drop a couple of inches and initially thought something had gone wrong with the frame pivots.
