Ask the retailer you are buying from, should be stated in the sales materials/cataloguesHello, been trying to get a straight answer to the question, "Do Orbea carbon frames have a weight limit". Can anybody help?
Not sure about Orbea, but if you are of a weight that makes you worry, I'd say stay away from Carbon. I tend to be around 100kg (+/-5kg) I've had a couple of carbon frames break & a seatpost, so I'm done with carbon now. I was under the 100kg limit on my last planet x, within 2 months & 500 miles the seatpost tube had a crack & I had a bit of a job getting the warranty replacement. I did eventually get a replacement in December, but I've not rode it yet & probably won'tHello, been trying to get a straight answer to the question, "Do Orbea carbon frames have a weight limit". Can anybody help?
Yes but did you weigh loads at the time?
I've seen failed ones.They make some pretty impressive things out of carbon fibre though. Most of my pals ride plastic, most of my club mates own plastics, most racing cyclists etc. I am yet to see a failed one, unlike steel, so you can see why I feel they work.
It's a fairly safe bet that no material is immune to failure. It's simply expense of replacing failed frames, and safety to keep me off them. If a manufacturer wishes to guarantee one for a 117kg man then great, but virtually no mainstream road frame manufacturer does.
Just an observation someone on here posted a link to a you tube video showing carbon fibre frames cut up and some of the defects inside. Interesting viewing but must have cost a fortune.....
Shaun
Shaun
