B)arallsopp said:I always try to acknowledge other cyclists, and am normally first
i read that as
"I always try to acknowledge other cyclists, normally with a fist"
bonj said:Roadies are definitely a LOT more miserable. Proper MTBers are very friendly, there will always be a nod, but if stopped then there will invariably be not just a nod but a smile and a few seconds admiring each other's bikes.
bonj said:
i read that as
Only 1 in 10 the case with roadies, the other 90% will often deliberately look straight ahead and deliberately avoid catching eye contact. Miserable as sin.
The trick is to do the type of nod that isn't a nod towards them in their direction, but a quick flick of the head away from them and back into line, which takes practice, and is usually seen to be done by 'stalwart' cyclists.
Give a slight, barely perceptible nodWigsie said:I do agree with the difference between MTBers and Roadies.....
Hold on! is there a new category of cyclist emerging? a 'stalwart' Cyclist? I know the definition of the word, but what does this mean in cycling terms?
Mud guards - yes or no?
Serious - yes or no?
John the Monkey said:d) Mentally assess the net worth of their bicycle and kit, waving only if it matches or exceeds your the value of your own bicycle and kit
Landslide said:True! When I'm out on my road bike and I greet MTBers, I often get a slight look of puzzlement before they respond!
bonj said:basically if you want to nod correctly at all times, you should probably learn how to tell the difference between a 'proper' MTB and a non-proper MTB.
they'd probably assume I was a social worker/paedo/gert raving woofter etc...
