Ajax Bay
- East Devon
@S-Express "You can swap the cassette for 12-28 with no other changes." I recommend that the OP does this first and see what difference they experience.
Have a play with this gear calculator (click will give you 50-34 compact and 9sp 12-25 sprocket). If you fit a cassette with a 28t largest (vice a 25t) you will gain exactly 12% gearing. This means in practice that if you can keep balanced on a cadence of 40 (say) you will climb 12% more slowly and therefore need (very roughly) less power. Still got to turn the cranks. HTHHow much of a difference is this likely to make?
